Query Intensity Greater than 0
I know I'm probably doing something stupid, but I can't seem to figure out how to use query to find channels used or not used in the show.  I've tried...
Query {is in} cue 0.5 thru 52 enter
Query Intensity {is in} cue 0.5 thru 52 enter
Query {isn't in} cue 0.5 thru 52 enter
Query Intensity {isn't in} cue 0.5 thru 52 enter
Every time it selects channels (or doesn't select channels) that clearly have no intensity above 0 in the show. I've asserted all the channels into the cue list with cue 0.1, so no blue zeros in the cue range I want.  What I was hoping for was...
Query Intensity {is in} cue 0.5 thru 52 {greater than} 0 enter.
I'm just trying to make a quick check cue for lamps used in show and I'm sure there has to be a way without using an external database or trawling through spreadsheet in blind.
Any help much appreciated,
Kevin
