Keeping effect parameters while recording in a multi-cuelist environment
while working on a current show I have realized several times that the console doesn't keep effect parameters (even if their are manual) when recording from multiple cuelists.
Example:
There is an effect running in Cue 1/3.5 and I change some of it's parameters. Then I want to record this (using [Record] ) as a new Cue 2/1. When I play back Cue 2/1 (after [Go to cue] [Out] ), the effect settings I recorded seem gone and are back to the default values (rate and size 100).
(I am working on an Eos-console running software version 1.8)
Any comments ?
Thanks in advance !
Matze
