So we ran into a interesting thing with merging show files today.
The designer mistakenly deleted cues 102 through 106. So we went back to Sunday's last save from after the dress run, and tried merging that range of cues into the current file. Channels that had a level that was tracking through those cues did not get pulled into the current file. Is that the correct behavior??
Having not used the merge function very much, I'm a little vague on what the actual behavior should be.
Any thoughts?
