I would like to know how to specify channels to be controlled in grandmaster.
Apart from that" Does anyone have a practical list of commands for executing a " Assert Cue " in cue list?
Kelvin
Kelvin
Hi Anne;
Thanks for your quick response to reply my question and I have another question about the content of submaster fader. Does any Cue and Preset Palettes can load into a submaster fader? If yes, can I run the cue in submaster like in any playback.
Moreover, is it correct no any preset palettes can load into playback fader.
Thanks a lots
Kelvin Leung
Anne~
After reading your response...
"Assert can be placed on a cue, a cue part, a channel or a channel
parameter. It is sort of like a block, which takes a tracked value and
treats it like a move instruction. But an assert will basically treat
a tracked channel like a move instruction for playback, but allows it
to continue to be edited like a track."
Is it possible to be able to place an "assert" on an entire cuelist? Or even better in future be able to possibly assign "priorities" to cuelists... so whenever a higher priority cuelist is played it will "stomp" another cuelist.
M
Anne~
Thanks for the response.....
Yes, Null values make sense.... record "remove" has always been a favorite when operating tracking consoles. In fact is "@ enter" the only way to make something a 'null" value??
Regarding Assert.... I, understand the functionality, however coming from a primarily moving light background, it isnt the "norm" how other consoles react, i'd want the ability to "assert" the cuelist, so that no matter when I ran this cue list.... everything would come back here....
Dont, get me wrong.... Its a very powerful feature, you're definitley taking Hard values, Tracked Values, and Lack of Value to an Entirely new level. Its definitely the right way to go about it, just lemme make it operate the other way as well......
Many thanks.
M
We have also discussed alternate ways of removing data from record target while in live, without having to set nulls and then record them. If in live, you were able to use [chan 1 color delete preset 1] to remove all of channel 1's color from preset 1, would that provide what you are looking for? This way you wouldn't need a seperate record operation to complete the command, and it would be less ambiguous what the results would be.
Thoughts?
MacStgTek:I guess I want the filters to not be tied to a specific function...
Actually do you but you just don't want it to be a global cue change. We'd want it to be more specified. It makes sense to explain in Hog2 speak where you pull manual values into selection and then remove anything you had just grabbed manually from whatever you specify in the command line. Something like Record Delete Manual Enter.
-j
-j
Well I'm cheating. In France right now so it's not 5am :-)
What I mean is that on the Hog2, when you grab any parameters of a fixture, no matter what it is (red, green, intensity at 20% at 50% whatever), when you Record+Remove from a cue/preset it will remove the data for the parameter you grabbed and not care that you grabbed red/green, etc.
-j
Anne~
We've been worried about Jason for ages.
M
