I want to create an gradient between two colour palettes for a cue, not as an effect, just a static state, is there a way to distribute the colour easily without manually changing them over 50 channels?
Channel x thru y Color Palette a + b
That will set x to Color Palette a, y to Color Palette b, and the other channels in between to a gradient between the 2 channels.
Jeff
OR
Channel X through Y CP 1 THROUGH CP12
will assign CP 1 to x, CP 2 to next chan, CP 3 to next, CP4 to next etc.
CP will wrap around if more channels than CPs.
That is exactly what I wanted and it worked perfectly, THANK YOU
