Running Eos Nomad v3.1.4
Ch 1 and Ch2 are different color changing fixture types (RGB Tape and Lustr). They are the only fixtures patched into show
Information is written into an arbitrary # of color palettes for each of them
Color flags display as expected on Direct Selects.
If you move Ch 1 AND Ch 2 to channels OTHER THAN Ch 1 or 2, DS Tile color flags no longer display.
Eg.Ch1 Move to Ch 3 Ch 2 Unchanged: result: No Change to Color flags.
Ch2 Move to Ch 4, Ch 1 Unchanged: result: No Change to Color flags.Move Both Channels to range outside Ch1-2 (does not have to be in same command) : result: Color flags disappear
Color flag reference seems to not respect Move To and will stick to reference Highest Ch in color palette that has NOT been moved.If I move either of my channels with Data stored in them back to Ch 1 OR Ch 2, the color flags return.
i'm seeing this as well, and i'm really surprised.
when you save the showfile and load it again, the console realizes that i has made a mistake and will correctly show the triangle again. but i agree, you shouldn't have to take that extra step.
I see the same thing happening in v2.9 as well. I wrote up
[EOS-54070] DS: Patch MoveTo of all channels in a Color Palette causes the Direct Select button to forget Color Swatch until show is reloaded
So I will note that I could reproduce this using channels with a single color type (Generic RGB 8b). If you have 3 channels in your CP, you have to move all three of them before the DS loses the Color Swatch.
