How can I run Cue or Preset Palettes for a submaster?
Hi Anne;
Thanks for your quick response to reply my question and I have another question about the content of submaster fader. Does any Cue and Preset Palettes can load into a submaster fader? If yes, can I run the cue in submaster like in any playback.
Because I could only playback the intensity palettes on a submaster , but others not after a cue or preset was loaded into submaster.
Moreover, is it correct no any preset palettes can load into playback fader.
Thanks a lots
Kelvin Leung
  • Hi Kelvin, you can assign a cue, intensity palette or preset to a submaster.  The syntax is [Cue] [n] [Sub] [b] [Enter], [Intensity Palette] [a] [Sub] [n] [Enter] or [Preset] [m] [Sub]  [y] [Enter].  When this is done, the information in the submaster is no longer referenced to the source cue, palette or prese - it reverts to absolute data.
    The submaster bump button can be assigned a fade in time, a dwell and a fade out time.   Because submasters are currently HTP intensity only, when a sub is faded out, values revert to the last LTP instruction.
    As long as the submaster is on the command line, you can press the load key of an empty playback fader and convert that playback fader to that submaster.
    Does this answer your question???
    a
    a
  • Anne~ Why does it break the reference to the cue/palette/preset?
    Is this intentional?
    I guess the option would be to use a single cue cuelist.
    Matthew Cotter
  • Hey Matthew.... I still owe you an email response!
    Yes, right now this is intentional.  And yes, you can use a single cue cuelist.   We may reconsider this behavior once we implement non-intensity LTP submasters.   So, we'll be pinging you for an opinion when we get to that.  More to follow.
    Anne
  • With that list of notes and comments... you're granted extra time with your homework assignment.... :)
