How to use BPM maccro on effect subs?
 I have two different Stepbased intensity chase effect recorded on two different subs. First I start in a cue one effectsub and I use the BPM maccro to adapt the velocity. I finish with learn and then stopEffect on the faderbump. When I start the new effectsub (by fader or the start/stopbump) and the use the BPM macro it puts in the command line the last effects and Error: Effect not running. Why the BPM macro does refer to the inactive effect and not the active one? What is wrong? It happens the same if I start with the second effect first. Thx a lot for the help!
