https://1drv.ms/f/s!Ag5AZbiMaHU6g7xJCnVVmuU6xAOABg?e=Qh8o3a
Link to accompanying docs, A Show File, Logs, and Video of what happened.
This instance I caught on a Gio@5 Primary with a Nomad as the Client, although I've seen it before in other cases, a Puck and Nomad Client on 3.2.3 also had a problem. At the time the solve was to downgrade the Puck and Nomad to 3.1.5 and it worked.
When the Gio@5 had the client connected, taking cues would cause the cue to loop. Cue List at 0 didn't take it out, usually I stopped it by disconnecting the Client or exiting to the shell on the primary.
The Logs are from the client connected.
