3.2.3 XYZ Disable does not populate in ML Controls
When you make a multi-selection of focus palettes in blind and enable XYZ on a fixture the option to then disable XYZ does not appear in ML controls. A workaround is to write a macro to disable XYZ, but I assume this behavior is not expected. I have not yet tested this on the latest version.
