Just having a discussion around using ‘go to cue’ to skip ahead to a future cue and loading a cue into playback then Pressing go. Does one offer any advantages/disadvantages over the other? I generally use go to cue if I want an immediate transfer into a cue and load if I’m say waiting for a cue to be called out of sequence, but just been told go to cue is only used for programming and even then it’s bad and you should always load a cue into a playback and press go as it’s better and uses all the desks features that go to cue doesn’t.
thanks!
