So I am programming a show right now with many cuelists (28 so far). Heres the problem, last night took all my lists to cue 0, no prob everything turned off, shutdown the system as normal. Came in this morning turned on master and noticed that 3 different lists had gone to cues on start up. I'll see if I can reproduce this again after tonites shutdown, when we come back Friday hopefully these list wont start again. Now i've been taking taking my lists to zero (Go to cue 40/0, 41/0, etc.) Maybe if I just goto Cue Out that would be better. But that shouldn't make a difference should it? Isn't Cue 0 the same as Out. I'd rather not goto Out because that also takes out the projection loops that are running, that the other programmer is running.
Thoughts?
Anyone else had this problem before???
