Wrong Home Value sometimes appearing - 3.2.5
Hi, I've been having an issue with Eos sometimes giving me the wrong values when using home. If I have no values recorded for a given fixture, certain parameters can show up in cues in this wrong Home Value. I'm not sure exactly how. But, I can replicate this by selecting a fixture in blind that has no data recorded and with a cue selected, I will Home one of the affected parameters and it will give the wrong value. This has caused Hippo Layers to be rotated on their head (probably what happened here: https://community.etcconnect.com/control_consoles/eos-family-consoles/f/eos-family/27812/z-rotate-keep-changing), Iris closed on Robe T2 causing no output all of a sudden, and strobing on a Solaframe 1500 that was absolutely not appropriate. I have found a workaround of recording a home value into my first cue. But this has caused problems for other operators here in the theater who didn't know about this.
The affected parameters/channels I have discovered are;
1. Robe Robin T2 (modified fixture profile, frost+shutter adjustments only modified) - Iris Channel affected
2. SolaFrame 1500 (modified profile, shutters modified) - Shutter Strobe affected
3. Hippo v4 layer (v4.5 through 4.8) - Z rotate affected
I'll send over a showfile via upload link if required.
v3.2.5 on Eos Ti
