OUT OF ORDER CUE
Hi
We currently have an issue with cues playing back out of order. The programming is correct and has not link cue or has be loaded.
We are running MTC and Midi Triggers and have also looked at the Qlab setup and programming which is fine
Never happens in the same place
This is what i had in the log, how can this happen
2023-12-19 15:46:47.676 Console MIDI Output: Go Cue 1/ 261.00 Raw=f0 7f 1 2 1 1 32 36 31 0 31 f7
2023-12-19 15:46:47.703 Context Run Cue Out Of Order 1 / 261 27
Also is this correct for a time code frame as it says its receiving a different number see below:
2023-12-19 15:38:53.142 Console    Time Code Resync (TCJ_JUMP): Current Frame: 1300528 /  Received Frame: 1404000 (Group 1 | 30 FPS)
