Total Newbie here, new to Element 2. Having trouble with ML pan/tilt control that is very difficult to use on the square grid. Is there a setting some where to make the mouse less sensitive? Thanks
have your tryed to use the Pan/Tilt "encoders" that are next to the square grid?
you can use them with your mouse wheel or simply tip on the roller.
Tried both methods but the sensitivity is just too corse to be useful. We can click on the top or bottom of the “rollers” but it takes multiple clicks to change position 1 degree. Very slow to use this method. I wonder if changing to a trackpad instead of mouse would improve things?
Two things to check:
Thank you.
Thanks, I do understand how the Virtual encoders work with the mouse.
We have both Intimidator Spot 255 IRC 13ch AND Intimidator Spot 375Z IRC 15ch...
I wish dragging the "dot" on the square grid in ML worked better but a very small movement makes the spot pan/tilt too fast.
Appreciate your help...
