Can you show a screenshot of the parameters in your profile so we can figure out what's using that 5th address?
Here you go:
In the Scan Rate row click where it says "8b: 5" and type 4 Enter.
Better?
I get this screen when I try to change the number of Ranges in the first Parameter 'Mode'.
Much better, Thank you, I hadn't noticed that. I put in a three so the Parameters would use the DMX values in the correct order. Any idea how I can get rid of the unneeded 5th Range in Parameter 1?
If it's still greyed out it's still a mode. In the range editor use the Remove as Mode button.
I may be misunderstanding some simple little thing but when I hit the 'Remove as Mode' Button on this screen nothing happens, the screen blinks but nothing changes that I can see...
Actually, I would like to keep parameter 1 'Mode', as I need it, but just reduce the ranges from 5 to 4? Can I do that? I don't see how to delete one range in this profile. Is this Laser profile locked somehow?
If I try to edit the values on this screen I get a screen that tells me I can't do that:
Send the showfile to eos(dot)moderator(at)etcconnect(dot)com please
Showfile sent, thank you.
Thank you for the showfile, I can see what's going on. You're running into a bug:
[EOS-53384]
Fixture Editor: If a Parameter is Removed with a Mode, the Mode cannot be edited
As a workaround I suggest you start over with a fresh copy of the 104 profile. Before deleting the Clip Select parameter open the range editor for the Mode parameter and use the {Remove as Mode}. Now you can delete Clip Select and other parameters you don't need as well as edit the ranges of Mode.
Does this help?
Moderator, You Rock! Thank you, that was the issue, I can make the profile do what I want now.
