Hello,
I have an Element 2 running v3.2, with a new Asus Laptop connected via network in Backup Mode.
Is there a way to run a command on the Backup cpu to change the Snapshot on the Primary Element 2?
Thanksomuch.
Hello,
Thanksomuch.
i would go with a macro that is calling the Snapshot.
In the macro you can tell wich device should execute it.
This is wonderful news, Thank you.
However, this leads me to another question: How do you choose a device in a macro?
A short look into the manual will maybe clear things a bit up
Manual-Page 470, PDF Page 486 (Manual v3.2.1)
{Target Device} - A macro can have a Target Device assigned to it. This allows a cue to execute a macro only on a certain console. Macros 471 • The Target Device can be a device name or User ID. These are assigned to a macro in the Macro Display by using the {Target} softkey and either selecting {Device} and {User}. Pressing {Target} will also display a list of connected devices and additional target options.
Thanks again for the additional details. It's awesome
