Is there a way to set the fade time of a Submaster from a within Macro command?
What would that command be?
Thanksomuch,
sfb
Thanksomuch,
sfb
SUB 10 @ 80 Sneak 5 Enter
This would bring up Submaster 10 to 80% in a time of 5 seconds.
Thanks for that answer, but I am not making myself clear. I wish to set the fade time for the submaster when you push the manual button from a macro. I can set it to 'Hold' but I can't set the time of the fade into the submaster. Thank you.
I'm probably not understanding you either but you can try learning a macro like:
[Sub[ X [Time] 3 [Time] {Manual} [Time] 3 [Enter]
which should save as
Sub X Up 3 Dwell Manual Down 3 Enter
Thanks for trying to help. I followed your directions, to no success. My result was:
Sub X Time 3 Time Manual Time 5 Enter
I'm trying to set the: Submaster [Tab 15] Up Time and Down Time amounts.
You need a macro that says 'Sub # Up # Enter'. (or Sub # Down # Enter). Unfortunately Eos doesn't let you add the Up/Down keywords at will (this seems an oversight). So you need to learn a macro while you go through the manual process for this, you can then manually edit it to be the correct syntax.
Please note that the instuctions from sk8rs_dad are for Live-Learning!
If you are not intending to change the Dwell or up-Time you can hit [Time] again to move on to the next value.
Yes, I understood sk8rs_dad meant live learning. I have tried this Macro in live learning prior to asking for assistance, and again, several times after seeing these posts. There is a problem with the live learning. when I move from the Macro Tab to the Submaster Tab, the Live Learning stops. Just like hitting the esc key. I am still unable to set submaster fade times from a macro.
Not sure why you are moving from the macro tab to the submaster tab. The whole command line should be learned in Live. If you hit Learn in the Macro tab, it starts to edit a macro, not learn a new one.
Ok, I see my error. I am mistaken. Sorry about that. I've got it now, and it is all good. Thanks for all the help
I've got it now. Thanks for the assistance.
