RE v1.9 Known Issue RND 0005182 Unplugging and plugging a Gateway causes Eos to lock up
Since we tend to unplug and replug our gateways, this issue is a concern.  I keep seeing this in Eos release notes since 1.8.0, which is one reason we don't update.
  • Howdy,
    I'll admit this description does sound a bit ominous, so I checked with our developers.
    The Eos lockup that is described could only occur if all of these statements were true:  (It might not even if they are, but all of these must be true for it to happen.)
    • You are using a gateway running version 2.0.0 or later code
    • You have RDM enabled on at least one port of the gateway
    • You have an RDM device plugged into the gateway on one of the ports with RDM enabled
    • You unplug and replug that gateway within 2 minutes
  • Tracy-
    Thanks for the clarification- I also thought the description was a bit ominous but since we don't unplug our gateways often, I didn't think much of it.  It is good to know that it is related to using RDM, because we do have RDM-equipped devices.
    -Todd
