Chauvet Rogue R3 Spot Colour Select Problem
Hi
I am testing out a Chauvet Rogue R3 Spot, and some of the colours it is producing don't correspond with what is shown on screen.
The preprogrammed effects on the Ion are also not outputting on the fixture correctly.
I have tried it in both 19ch and 25ch modes, both modes have similar issues.
I've used both the Ion and the Nomad with the most up to date software and fixture libraries available to date, August 14th 2024.  Same errors occur using either for control.
For example, in 25ch mode, left column shows what is selected using colour select 1, right column is what the fixture is actually outputting.
Open            Open
Light Blue     Light Blue
Green           Red
Red              Magenta
Magenta       Dark Blue
Dark Blue     Orange
Orange         Magenta
Open            Split Open/Yellow
Yellow           Split Yellow/Light Blue
Light Blue     Split Light Blue/Green
Green           Split Magenta/Red
Red              Split Dark Blue/Magenta
Magenta       Split Orange/Dark Blue
Dark Blue     Split Orange/Magenta
Any suggestions on what might be causing the problem?
John
