I want to automate a spot, tracking across the floor with other than a direct FP to FP. Say a slight curve is required. Is there an effect I can use to move the spot in such a fashion?
Are you just looking for a more interesting transition between two FP or are you trying to live track an actor or object on the stage?
Live track actor on a marked path (The Yellow Brick Road!). The actor is singing which generally puts their steps at the right place at the right time.
