Best practice to control relays from Eos
Hello we recently replaced some dimmers with Relays.
To switch on the Relays on our Sensor rack I made a Sub 610 to turn them on with a macro.
Solution A wich I use now is: set the priority to Shielded and Exclude Rec.
But now I came across a showfile by someone else and they used a different approach:
Solution B has the sub at Priority 10, a channel filter, and Exclude Rec / GM / Solo / Inhib
In what way does the sub (or relays) behave different with these settings?
And what do you think would be best practice?
