Hello, what else could pattern effect mean in my ect puck for fixtures?
Could be Gobo. Static means not moving dynamic could mean shake
Hi there,
Geoff allready answerd your question wonderfuly.
But i want to share some trick with you.
I asume you do have a working fixture patched in your desk and only try to understand the wording from the manual vs the desk.
As you can see in the Manual, there is a Ch number written.
You now can have a look at the fixture in your desk and search, in the Fixture's List what is writen there.
A small example here. I took a High End System - Halcyon Gold and i am currious what Ch 11 is named in my Desk.
As you can see, in the Fixture Profile-List, Ch11 is called "Gobo Select" and is assigned to "Image".
You could now investigate a little further by double-click in the same Row on the "5 Mode" in the Column "Ranges" and see what different modes there are. But that is not something very important.
That is a quick way to finde the naming in the EOS-Software.
Hope that will help you on your way.
Even though it could be not what you originaly intended to ask for.
yours
thilda
