I think this true of other instruments as well, but I am using EOS 3.2. I have patched FXPar 9s in 9-channel mode. There is both an outer ring of LEDs using RGB and an inner LED using RGB2, the color picker only affects RGB1 and then I have to go in and manually change the RGB 2 settings to match those of 1 if I want a heavy saturation otherwise I have white light coming out of the center. Is there a way to get a second color picker or have the one do both?
