I'm new to Eos and I'm trying to make an aurora borealis effect with 5 spectracyc 200 rgbw 608s and all of the forums/guides haven't been helpful so far. How do i go about making this effect?
This might be something you could use pixelmapping for. An Effect Layer with one of the random red blue patterns using blue and green as start and end color.
How would i set that up in ETCnomad?
For the general understanding of pixelmapping you can find some videos here: https://www.etcconnect.com/Support/Tutorials/Expert-Topics/Virtual-Media-Server.aspx
This is what i did for a quick mock-up, assuming those 5 fixtures are channel 1 to 5:
Tab 9:
In Live set your fixtures at full with RGB all at full.
I set the server channel at full (Chan 10 in my case), Crossfade at -100 (that's its minimum):
And set the following values for the effect layer (Chan 11 in my case):
Intens At Full
Intens_3 At 50
Start color: choose something green/cyan
End color: chose something blue/cyan
Playback_Speed 20
File Input_File_Select_1
Width 5
Height 1
Tab 10 shows you a preview, this is what i get:
I hope this helps!
