I just found that the offset softkey is not available in blind SUB. It is available in blind CUE.
1.9 release software. Eos.
just had a situation in patch, when the offset key would have been handy, however it doesn't work? it's there, but to no effect. for example when i want to label my sidelights which are on consecutive channels but the odd ones have cold gels and the even ones have warm gels. or boom that have scrollers on every other intrument...
am i being stupid? or unreasonable and nobody else think that'd be handy?
cheers from switzerland
felix
Offset in patch doesn't support even/odd. But if you start your channel selection with the warm gels (for example) and offset 2, you will get every other one in the list. If you start your channel list with the cool gels, and offset 2, same result.
Hope that helps.
a
