Removing cyan "STOP" from intensity and NIP values
I recently opened a show file made by another programmer that contained cues in which a cyan "STOP" was displayed in a few cues next to intensity and NIP's for some channels.  Those parameter values can be changed and updated, however they would not replay due to the "STOP" next to the parameters.
Any ideas?
moved to Eos forum from Hamilton Programming Project
[edited by: eos moderator at 5:17 PM (GMT -6) on Sat, Mar 8 2025]
  • The STOP doesn't have anything to do with playback of the parameter values, it's a so-called Stop All flag for effects.
    You can get rid of the STOP with the syntax
    Chan 1 Effect Enter
    Does that help?
  • I initially thought it was an effect flag; however, there are no effect running in the cue.  I know I can issue a "Stop All" flag by <channel> {Stop Effect}{Stop Effect} [Enter], but is there a way to remove that flag?
  • Yes, there is. In Blind the syntax Chan x [Effect] [Enter] will remove the STOP.
  • "In Blind" was the key.  Odd that doing so in "Live" simply accepts the command without any change to the flag.
    Thank you.
    -Robert
