Cannot edit magic sheet
I am using EOS for the first time on a show The theatre has a base file which I am editing for the extra lights I will be adding - using NOAD on a laptop. I have successfully added them to the patch sheet and am now trying to add them to the Magic Sheet. I can drag a fixture from the library and rotate and stretch it. However, I cannot change its properties from the editor: if I select a colour it does not change the fixture and the drop down boxes do not drop down. (I am in blind mode).
Is there some feature to lock the magic sheet, or am I doing something wrong?
ps how do you delete an item from the magic sheet, or will that become obvious when I can edit them?
