It can't, you need a computer. Plug the programming wing into the computer, and install Nomad on the computer, and then you're good to go. You'll need a Nomad USB key to unlock it (without that, it'll be in visualiser mode only).
Okay. Could I buy the ETCPuck instead and plug it to the PGW and send a DMX from the PGW to the wall?
Yes, the Puck would be the computer and USB key in that scenario. Think of the Programming wing as a keyboard with DMX outputs.
Okay, thank you!
But with all the costs summed up you might be equal with an IONxe. Consider it.
The Programming Wing is "just" a fancy Keyboard
An IONxe, even though it looks a like, is a great and small desk of its own.
You can connect 2 Monitors, have 4 DMX Outputs and 2 Network outs.
I was thinking of just buying a Puck and a Gadget II as it would be cheaper.
