Multiple intensity Control (Starcloth)
  am a relatively new user of Eos, struggling with control of ShowLED Chameleon starcloth. It has two intensity parameters (max and min for ‘twinkle’ effect). The min intensity attribute is treated by Eos as a NIP and, as a result, presets to its next level when Tracking parameters (ie lights up in blackout if next cu3 has starcloth in it!). Given the nature of our operation, Tracking mode is our default and having inexperienced programmers I don’t want to change this. How can I reconfigure the fixture such that both max and min intensity attributes are recognised as ‘intensity’ for tracking purposes and so minimum intensity does not preset as an NIP.
I am thinking a custom Multi-cell, with the cell only having an Intensity parameter and making that the minimum intensity attribute and then deleting the minimum intensity attribute from the ‘master’ channel. Is this the best solution? Is there a better solution? If this is a workable solution, how do I do it?
Thanks in advance
  • My mistake - for ‘Tracking’ read ‘AutoMark’
  • a little work around for this marking issue could be add 0.2 of intensity in the cue before. This way the auto mark should not happen because it has an intensity above 0. You may have to adjust the intiensity to get it to work but at such a low value there might not be any light output but the console sees it.
  • Hi.
    Afaik there's no way to turn off Automark on certain fixtures (which i find quite annoying to be honest).
    I wasn't able to find a two channel fixture for your Starcloth in the Fixture library. Did you create a custom fixture or did you import it?
    The problem is likely that the Min Intensity is in a NIP category (FCB) by default.
    For a two channel fixture its super easy to build a custom fixture with Intens and Intens 2 as parameters. This should stop AutoMark from happening.
    I'm not totally sure that all Intens parameters don't AutoMark (Intens Macros for example might AutoMark). Just tinker around a bit and find some parameters that make sense.
    Keep in mind that if the fixture has no Intens parameter (if you do Foreground/Background Intens for example) you cannot control it with the Dimmer wheel or conventional "At" Syntax.
    Multicell might be a bit overkill for a two channel fixture and might be a bit intimidating. Also it eats space on your Live Summary :D
  • Intens is the only parameter that is excluded from Automark.
    You can disable Auto mark per cue and per cue part. So you could have your star cloth in separate parts or in a second cuelist
  • Thanks for the input - the starcloth is patched as a Chameleon M10 from the fixture library, so it has 10dmx addresses with one assigned to Intensity and one to Minimum Intensity. Is there a way to make a cell where the Minimum Intensity is recognised as an Intensity so that the Minimum Intensity is not preset when the channel Marks for the next cue?
  • Thanks for the input. This is similar to my current work around, but it requires a trawl through the cue list to identify all cues with the starcloth in and then assign parts for those cues to force-stop the auto-mark. the starcloth is patched as a Chameleon M10 from the fixture library, so it has 10dmx addresses with one assigned to Intensity and one to Minimum Intensity. Is there a way to make a cell where the Minimum Intensity is recognised as an Intensity so that the Minimum Intensity is not preset when the channel Auto-Marks for the next cue?
