Apollo Spectra3 color scroller
I talked to someone a year ago about a problem with the Spectra 3 fixure in the ion software. I patch the fixture and choose the Spectra_3 personality . When I choose the channel , the scroller encoder wheel goes from F1 to F16 in one click. With the Apollo Smart scroller 7 (which we also have) the encoder wheel moves from F1 to F1+ to F2- all the way to F16 like it should.
How can I work arouund this?
thanks
Mark
  • Can you just use the Smartcolor profile without the Fan channel?  I have both of those, but on an express system, and the frames are not that far off from each other.  You could then just calibrate the scrollers to line up the same.
  • There are 2 workarounds for this issue:
    The Min and Max values of this Scroller match - which looks odd (compared to other Scrollers):
    Frame 1     Min = 0      Max = 0
    Frame 2     Min = 16    Max = 16
    Frame 3     Min = 32    Max = 32
    Frame 4     Min = 48    Max = 48
    And so on….
    Via the Fixture Editor –
    If you change the Max value to 1 less than the Min of the next Frame the Scroller appears to work (can hit all of the Frame values):
    Frame 1     Min = 0      Max = 15
    Frame 2     Min = 16    Max = 31
    Frame 3     Min = 32    Max = 47
    Frame 4     Min = 48    Max = 63
    Frame 5     Min = 64    Max = 79
    Frame 6     Min = 80    Max = 95
    Frame 7     Min = 96    Max = 111
    And so on…..
    Another workaround is to build a Custom Scroller that has 16 frames.
    This is on our list to address in software.
    a
  • I assumed that if I was using both Smart scrollers and spectra 3 scrollers in the same show, I couldn't callibrate one without effecting the other. But from Anne's post on another thread it appears that the calibration needs to be done for each unit and your scheme would work
    thanks
    Mark
