Manual Data overrides Submaster but won't update into cue?
I feel like this a change in behavior, but maybe my expectations are wrong:
Channel 1 at Full on Sub 1
Sub 1 Exclude from Record, HTP, Same Priority as Cue List.
Sub 1 at Full
Manual Data: Channel 1 @ 50
Channel 1 moves to 50% and overrides Sub*
Update Cue 1 --- Syntax Error, Channel List Empty.**
* - I would expect the Submaster to keep Channel 1 at Full here, no?
** - If I'm seeing manual data on Channel 1 here, shouldn't that data update into the Cue?
I feel like I was previously able to write cues with submasters up and record manual data that was under a HTP/Exclude Record submaster without affecting the output. Here, I am affecting the output AND not able to record the manual data that's attached to the sub.
Is this a change? A bug? Or do I have a bad memory?
