Clearing a Split Time Syntax
Hi
So it seems to me that the method of clearing a split time is backwards.
If I have a cue with a split time (let's say 4/6) and I want to change the time to an even 5 seconds, shouldn't I be able to just type [cue][#][time][5][*]? I would expect that command to clear the split time, but really it only changes the upfade time.
If I wanted to just change the upfade time, I would type [cue][#][time][5][time][*]. Just like typing time [5][/] on an O2. In that scenario, I am acknowledging that there is a downfade time but that I don't want to change it.
Right? Is my logic backwards here, or is Eos's logic backwards?
EDIT: Also, I would expect that if I say [time][5][time][5][*] I would also effectively clear the split fade, but that doesn't seem to be the case either. It still shows me a split time, even though both sides are the same. Why would I want that?
The 1.7 manual even says "If a cue is provided split fade times with no delay on either side, and those times are later the same values, the split time is cleared."
[edited by: jakedeg at 3:03 PM (GMT -6) on Thu, Oct 7 2010]
