ion dimming curves
Where in the manual (1.7) is the definition of the different dimming curves?  I want to apply a "on at 1%" curve to several dimmers.
  • It's been a while since I played with v1.7.  In the manual, curves are documented in Chapter 23 on (p. 271-275) under the heading Storing and Using Curves.
    Specifics are not in the manual since Curves are meant to be extensible by a user. To see the curves available (v1.9 and maybe 1.7 but I don't have that version installed)
    • Press the [Displays] key.
    • Select Record Target Lists in the CIA Browser.
    • Select Curves to see the list of available dimmer profiles.
    • Click on a particular curve to see the details.
    They can be applied to a Patch or a Cue. You probably want to apply it to your patch:
    [Displays] {Patch} {Attributes} [1] {Curve} [9] [0] [5] [Enter] - applies curve 905 (Full at 1%) to channel 1 intensity.
    [edited by: sk8rs_dad at 2:26 PM (GMT -6) on Fri, Dec 3 2010]
  • Can't say I looked in the manual, but I cheat and look in the Record Target List / Curves in the CIA.
    901 - IES
    902 - Slow Bottom
    903 - Fast Bottom
    904 - Fast Top
    905 - Full @ 1%
    906 - Out @ 100%
    907 - Preheat at 5%
    908 - Preheat At 10%
    909 - Hot Patch
  • Yea, I found it.  Just a panicky post. thanks
