I'm running 1.9.6 on an ION with a 2x20 fader wing. If I Shield a sub and record cues it works as expected, however, if part way through programming I want to record those channels contained in the sub in a cue I have a problem. I can un-Shield the sub and the Tombstone display correctly has the S removed from the channels that are in the sub, but if I give those channels an intensity value, either by raising the handle or from the keypad, the channels are not recorded in the cue. I hope that this is not the intended function. The only way I have found to give those channels an intensity value is in blind.
