Patching Bug
Hi ETC.
This predates 1.9.6.
In Patch, I select channel xx [Enter].
THe screen jumps down to display that channel.  It displays the columns to the right.
I hit Attributes to look at the ML settings.  The display reverts back to channel 1, so I either need to scroll down to channel 100, or re-type 100 [Enter].
If I hit a SK to edit the attributes of my original channel xx, the change is applied correctly: the Ion has still selected the correct channel, regardless of the patch display.  The details in the CIA box are still accurate for xx, but I can't compare that channel to the nearby channels for settings, because the display has jumped all the way to channel 1.
This display jump occurs when moving between any of the three displays: Patch, attributes, database.
Thanks.
Andrew Riter
