Channels showing errors
We run and Eos, RPU, Sensor system and our normal configuration is RPU as Master/Primary and Eos as backup with device descovery enabled for Sensor feedback, etc.  The Eos was accidentally switched to Client mode recently and every channel patched to a Sensor dimmer was showing an error on the screen.  If I went to About and tried to check the errors there were none.  After a reboot I couldn't even look at sensor data.  When I switched the console back to Backup all the errors went away and everything was functioning as normal.  I wish I could say which user the RPU was setup as but I wasn't able to check before leaving for the night.
Is this a glitch or is there some communication cross-talk that is occuring here?
