Why "Proportional Fader" as default for a Cuelist ?
I have wondered recently why a fader is set as "proportional" as the default state for a cuelist. And what is the effect actually ? Doesn't it make more sense to have it set as "Intensity Master" as a default ? Normally you want to control the intensities with the faders you are putting a cuelist on, no ?
Just wondering - maybe I haven't realized the possibilites of the "proportional" setting.
Thanks !
- Matze
  • Good question.  When I look at showfiles, about 1/2 of the time the faders are set as proportional and the other 1/2 as I-Masters.  How these are set depends a lot on the types of shows you do and what you are used to.  I don't think there is a clear "winner" here in terms of what people want to do.  The initial behavior of the faders was proportional.  I-Master options were added in later.  So, by default the faders work the way they have since the initial release.
    a
  • Interesting...I have to be honest...my assumption is that when the fader is set as "proportional" it is because the fader isn't used at all. Well...at least that is how I work. But you are right, it depends on the type of show of course.
    And wow, it only took me about three weeks to respond to your post ;)
    Thanks, Matze
