Stop a Running Effect - ION 2000
I have created an Effect and it is working the way it is meant to however, I can't stop it other than selecting each fixture and manually stopping the effect.
Is there a command to stop the Effect 1 from continuing to run? Also if I add an effect to a cue when I go to the next cue that doesn't have the same effect running, will it stop running once the next cue is executed?
I just want to be sure about these effects before I start adding them to my cues. Again, I apologise in advance if this is a noob question. :)
