How many addresses should my DF-50 diffuser be using?
Hi, I am fairly new to lighting.  We had a professional come out and set up our Ion board and patch everything.  He tried to take one of the channels to power on our DF-50 diffuser. There is a slider on the fader wing for the hazer.  Sometimes it works, but most of the time it does not.  The diffuser tries to turn on but it is not at full power and the circuit trips on the back.  I have the dimmers set to switched, but it still does not work.
I checked in Patch at the channel the diffuser is using and this is how it looks:
Channel    Address    Type
512    P1       57          Dimmer
          P2                     Non_Dim_at_50
          P3                     Dimmer
          P4                     Dimmer
          P5                     Dimmer
          P6       58          Dimmer
          P7       59          Dimmer
          P8       60          Dimmer
Can you tell me if this looks right for what we are trying to do?
  • I had this note in my archive of manuals.  You should be able to tell by looking at the machine whether you have a DMX control cable attached or are just using a non-dim.  If you have both, that could be the issue.  Regardless, it looks like you have too many channels patched to the unit.
    NEW DF-50 DMX OPTION
    The DF-50 DMX version, now available, allows three modes of operation.  This new DMX feature enables control of the DF-50 from a light board, from internal auto settings or from the standard manual On/Off.  The DMX interface is fully USITT 1990 compliant featuring an address range of 1-512 and industry standard 5 pin XLR connectors. The DMX input is short circuit protected.
    How the DMX and AUTO feature works
    The DF-50 DMX uses a single address to provide proportional control. When the DF-50 DMX version is in the DMX or internal auto settings mode it operates on a 100 second duty cycle.  These modes allow the user to set the DF-50 to cycle ON and OFF as a percentage of 100 seconds.  For example if the unit is set to 60% the DF-50 will automatically turn ON for 60 seconds and OFF for 40 seconds until the user changes the setting or removes the power supply.  When the power supply is disconnected from the DF-50 the settings for the most recent use remain stored for operation until the power supply is restored,
  • Thanks for the reply.  I do not have the unit with the DMX input.  It is just a power plug.
    How many channels and addresses should the unit be using?
  • Thanks, i think I got it working now.  I appreciate your help.
    512    P1       57          Dimmer
              P2                     Non_Dim_at_50
              P3                     Dimmer
              P4                     Dimmer
              P5                     Dimmer
              P6       58          Dimmer
              P7       59          Dimmer
              P8       60          Dimmer
    The pertinent info that is missing is which dimmer (or circuit) the DF-50 is plugged in to.  The patch info above shows that you have 4 separate dimmers (addresses) patched in to channel 512.  There are also 4 empty parts (P2 through P5) that probably had something patched to them in the past, but don't anymore.
    You said that you set the dimmers to switched mode- did you do this at the dimmer rack? If the circuit that the DF-50 is plugged in to is set to switched mode (on the dimmer rack, not the console), then it should turn on at full power once the fader gets to around 40% or so.  No matter what you have done in the console, a dimmer set to switched mode will not dim up and down, only switch on and off.
    It sounds like the dimmer that the DF-50 is plugged in to is not set to switched mode, so it is dimming up as the fader is brought up.  That would be the first thing to check.
    If you want to get rid of the extra dimmers in channel 512, you can go into patch, switch to address mode using [format], and do {address} @[enter] for each of the dimmers you are not using, leaving the one dimmer that the DF-50 is plugged in to as the only thing patched to channel 512.
    Hope this helps-
    -Todd
  • It's also a good idea to use a relay module as well with the DF-50 instead of just a normal dimmer module so that it's receiving clean power.
    Eric
