Hi Anne,
First of all let me say that I find the new Media Server fabulous. I have been playing with it since the Beta version. I know I have barely touched the possibilities. That said I have one request and one question. The request is about the default pixel size on Effects layers. It currently defaults to 12 x 12. I was wondering if you could add either the ability to assign a size for the Pixel Map in the pixel maps setup, or have it default to the size of that map. The first would probably be better but the second would also work. It just saves time when programming.
I am using the server to primarily control Icove MX units. My problem is that as with most RGB fixtures full RGB is not white. We I have found settings that get much closer to white(instead of the pink the 100% RGB produces pink. Is there a way to tell the media server when it sees white in the media to use my values instead of full RGB? I know there probably isn't but I am hopeful.
Once again thanks for a wonderful program update.
Andy Kassan
