HL group selection
When working in a Highlight/Lowlight state it would be nice to select a group. And then select a channel in that group with out loosing the original group selection.
I have also seen that on the display when I am Nexting and Lasting through a group with a lot of channels in it, 100+, that every so often the entire group will flash to HL and then revert to the individual channel selection. Is this normal?
  • Hey Ben.  We are adding syntax in 2.0 that allows you to select a group and specify a channel within that group all in the same command line - to avoid the "group all flash to highlight" upon initial selection.
    If you select through a channel list/group, next and last specify individual channels to work with, but the entire selection is maintained.  You can get back into the entire selection at any time by pressing [Select Last].
    Hope that helps.
    a
