+/-% buttons and discrete timing
I know that by default the +/- % buttons are set to +/-10%.  I have set them to +/-5% because that's the way I like it. However, when the operator uses them, the command line still shows: +10% or -10%.
My operator somehow put a 30 second discrete time on a single channel (dimmer). I tried to change it to a 3 count to match the rest of the que by typing Channel xxx Intensity Time 3 but that didn't work. Nor does the manual say how to delete this timing. Perhaps she specified a parameter other than intensity (if that's possible on a dimmer channel). Is there a way to see what parameter was set to 30 sec? None of the que's times were showing as a 30 count.
ahh teething pains......
