Problem cue.
hello, when I edit a cue channels are recorded in the next cue.
What am I doing wrong?
Problem cue.
If you do not want changes to track forward into subsequent cues, use the [Cue Only] button before recording or updating.
There is a wealth of information about tracking in our educational resources:
http://www.etcconnect.com/support.education.aspx
-luke-
This is true even using only cue.
Note
happens when I edit.
Are you editing live or blind? Is the desk in track mode? If the desk is in track mode:
and you are editing live, the QOnly command is applied at the point of updating or recording.
or if you are editing blind, the QOnly command is applied at a channel parameter level when the change is made.
a
