Ion network adaptor offline???
we hooked up our RVI to our Ion tonight and now the network adaptor doesn't seem to be working . .  this console and RVI were working together less than a week ago ..
is this a "user fixable" issues .. or did the network card in my Ion bite the dust .. how can I tell?
I go into tech tomorrow night . . . ARGH!!!
p.s. I am having A LOT of Ion issues lately . . .
  • a little clarification . . .
    after the Ion boots up and we go to ABOUT it says NO NETWORK DETECTED. . .
    in SETTING in the shell it says NETWORK ADAPTOR OFFLINE
    the hub indicator light for that channel go out after booting up .. and there are not lights near the Ethernet port ..
  • Howdy Paul,
    What is the Make/Model of the Hub/Switch you are connected to? What network speed/mode is it
    running in? 1GB and Autonegatiating or Full Duplex? Could you swap out a different switch and
    see if the problem continues?
    Could you find this information out and then contact your dealer or ETC Tech Services for further troubleshooting?
    For technical support in the Americas, please call 608/831-4116, or toll-free in the U.S. at 800/688-4116.
    For technical support in Europe, please call (+44) 20 8896 1000.
    For technical support in Germany, please call (+49) 8024 4700-0
    For technical support in Asia, please call (+852) 2799 1220.
  • Hi Paul
    It is sometimes the case that the network card on an Ion will disable itself if it doesn't see anything on the Network upon power up. If you are running directly into the RVI, just try making sure this is powered up first, before the Ion and it should be fine.
    Just a thought to try.
    Warren.
