ION linking
So i'll try to give the picture:
Numerous cue lists placed on multiple faders.  Let's take cue list 1 on fader 1 as an example but they all do it.  Fader set as iMaster, HTP and Assert.
Cue 1/1 has a couple of colors and some gobos but all static. No movement.
Cue 1/2 has the same however colors switch fixtures.
Cue 1/3 now has one set of movers with a very slow rotating gobo.
Cue 1/4 has the same but more movers with a very slow rotating gob.
Speed of course doesn't really matter here.
Cue 1/4 is linked to 1 so that it can be tapped over and over and it will continue making changes.
I tap the bottom bump on fader 1 to set cue 1/1 then bring up the fader.  Cue 1/1 runs.  I then tap through the next 3 cues and all changes happen as recorded.
When it goes from cue 1/4 back to cue 1/1 everything changes to the cue 1/1 look but the gobos keep rotating.  If when in 1/1 the top bump is tapped it will send everything into white home then out.  When tapping the bottom bump back on again for cue 1/1 then it does what is supposed to do.
Only when tapping backwards from 4 to 3 to 2 to 1 or from 3 to 2 to 1 will cue 1/1 show as recorded.
Thoughts?
