Is there a way to lock the display settings (ie 2nd monitor on and position) so that us rental houses don't have to worry about the console not seeing a monitor if the client doesn't have them hooked up to the console correctly the first time. We have to field a good number of calls from new Ion renter's that need to know how to re-enable the second monitor.
Is it something you could consider adding to the next software revision as a check box in setup maybe? Would make a great console even better!
