During CUE there was talk about adding a group check to the channel check screen on the iRFR app would make it easier to check the rig on those slammed days
Hi Kevin. Yes, this is still out intent. No ETA yet.
a
Thanks Ann
What are the chances of adding a way to record/update Focus Palatte on the iRFR .would be very cool to be able to stand on stage and tweak moving light focus or is there a tip or trick for doing that would help do this already
Kevin Bishop
Yes! That would be awesome. I program by myself all the time and focus lights to myself on stage. I often need to update the pallettes after a rehearsal. It works great to do it on stage, but it's a bummer to have to run up to the booth to press Update - Enter between each pallette update.
You can do this now using a macro which just places Focus Palette on the command line.
Nick
Yes this is true but would be better if you had a page that was built with all the buttons that one would want to do this quickly from one screen could be combined with a scroller update fuction would make life as a one man lighting department much easier.
