Hi, I'm in the middle of transferring an existing show into EOS. In the existing show file the pan/tilt values are expressed as 16-bit values, which I need to convert to degrees. I'm reasonably sure I know how to do this but I would like to just confirm what DMX values the EOS outputs at each end of the pan/tilt ranges. I'm working offline and I don't have access to a console right now so I can't check this for myself until next week, and I'd rather not get this wrong...
For a tilt range of -135 to +135 degrees, can I assume that -135 degrees => DMX 0, 0 degrees => DMX 32767, and +135 degrees => DMX 65535?
For a pan range of -270 to +270 degrees, can I assume that -270 degrees => DMX 0, 0 degrees => DMX 32767, and +270 degrees => DMX 65535?
If someone's able to confirm that those assumptions are correct then I can quite easily convert the existing show's 16-bit values into degrees for inputting into EOS.
Many thanks,
David
