So I have just set up the Ion Client on my laptop but I don't get the full screen.
In Live Split Table, I dont see any cues from the cue before the active cue to the bottom of the cue list.
Any suggestions?
Jamie
Any suggestions?
Jamie
Have you checked the "full screen" setting in the shell?
Exit or don't start the Ion console program, just be in the little window that has a "Settings" button.
On the General tab, just under the language options there is a check box for full screen display.
Hi Jamie,
did you maybe install the Eos Family Console Software file instead
of the Offline/Client file?
Jamie,
Depending on the size of your monitor you may only be able to see a single cue when you are in the split screen mode. You can press [Tab] on your computer and cycle through until you get to the cue list or select [Tab][2] I believe should be the correct tab for your cue list.
I am often on single monitor on my laptop and can only see a single cue when in the split screen tab.
Hope this helps,
